emoncms after some hours or days inputs inactive
Hey,
I have a problem with my emoncms: For some hours everything is working fine.... I use the raspberrypigateway (http://emoncms.org/site/docs/raspberrypigateway) for my emoncms system.
After some hours or sometimes the inputs are inactive.
Can me help somebody??
Thanks a lot!
Christoph
ukmoose's picture
Re: emoncms after some hours or days inputs inactive
It would be useful to know a bit more about your system.
Such as:
Which version of the rfm12pi you are using?
Are you sending data to emoncms.org or a server you have set up?
Has it always done this or has it "worked" like this from new?
Have you tried the Troubleshooting steps on the page you linked to?
fluppie007's picture
I had the same, I think it got broken with updating. Because some file is in use (controller.php or something) it won't update and will break stuff.
I did a clean install with Dave McCraw debian pkg:
https://github.com/Dave-McCraw/pkg-emoncms/blob/master/docs/install.md
chrissel's picture
Hey,
sorry for the late reply....
I tried to install the Dave McCraw Version like you told me fluppie007 but I did not manage it to run up the system....
after that I made the normal OEM/EMONCMS installation like it is told on the homepage and tata.....
The system is running now since 2 weeks!!!
I just made directly an update for the system via ssh.....
Thank you for your support
chrissel
