Cannot create feed anymore
I created several input / Feed /dashboard month ago without issue.
Now I am back with 2 new inputs and I cannot create the corresponding feeds (it makes an error without message), see screenshot attached below.
I am running 8.1.1 version
Any idea where it could come from and how to debug?
thanks
darrepac's picture
Re: Cannot create feed anymore
I can create a histogram feed but not a log to feed...strange
Note: I am running it on RPi
darrepac's picture
Solved: need to do the following
sudo mkdir /var/lib/phpfiwa
sudo mkdir /var/lib/phpfina
sudo chown www-data:root /var/lib/phpfiwa
sudo chown www-data:root /var/lib/phpfina
