kWh/d Comparison
Hi all
I am trying to add the kWh/d Comparison Visualisation, but I can not seem to find it anywhere? is it not part of the normal build? I am running 8.1.1 on a Linux server via apt.
Cheers
Nathan
Re: kWh/d Comparison
I dont think the kWh/d comparison vis is currently working, the d3 library isnt installed as default. the code for it is still in the repo here though: https://github.com/emoncms/emoncms/blob/master/Modules/vis/visualisation...
Might need to check that its requesting data from the right api.
