Where to input calibration values ?
I just got a system setup with a emonTx V3 and a Raspberry Pi with a RFM12Pi and a hard drive running with emoncms.
I am getting data from all 3 CT’s and the V (RMS). I now need to calibrate these feeds, but am missing a really basic step in that I can not find the file to put the calibration data in.
What is the name of the file and directory that I place these calibration values in ?
I installed emoncms via the 2014-02-23-emoncmsraspberrypihdd_stack.zip method, so I assume it is somewhere on the hard drive, but can’t find it.
Feel pretty stupid that I can’t figure out where to input the calibration values.
ukmoose's picture
Re: Where to input calibration values ?
Take a look at the calibration page under the building blocks tab above.
You could also search for "emontxv3 calibration" using the search option above as there is a forum post that went through these steps
