How to look at your energy consumption on the web
This tutorial details how to first connect your energy monitor to the web with an ethernet shield and then how to set up a database on a web-server for the ethernet shield to connect to and then to finish how to read the data from the database and produce a nice zoom-able graph using flot.
I'd like to thank John from jarv.org for his tutorial and help on logging using the ethernet board although he is using open flash charts and sql lite instead of mysql and flot much of the implementation is very similar.
Part One - The Ethernet shield
The first step is to get an Ethernet shield for the Arduino. There are two Ethernet shields available to my knowledge:
- The official ethernet shield from Arduino themselves. Costs £29.00 from cool components.
- Nuelectronics ethernet shield which is a bit cheaper. Costs £12.50 from nuelectronics.
The arduino sketch below works with the official ethernet board library. There is a guide to do the same thing but with the nuelectronics board here: Nuelectronics web client example
Once you have your ethernet shield the next step is to connect it up to an Arduino and upload the sketch.
Arduino Sketch
Note: This sketch is just sends set values out to the server, its just to show the basics needed. Have a look at the whole house energy monitor documentation page for an example of how this can be connected up to the rest of a setup.
Download: SAethernet.tar.gz
There are a couple of changes that need to be made to the arduino sketch now so that we are ready for the next section.
- Make sure the MAC address and ip of the ethernet board are unique on your local area network
- Enter the ip of your webserver. If you have a shared hosting you can find the shared ip using a trace-route program, you can trace-route from network tools in ubuntu.
- If you have a shared hosting you will also need to change the "GET /cgi-bin/post.pl?L=" to include your server url: "GET yoururl.org/cgi-bin/post.pl?L="
The next step is to upload the sketch to the Arduino and then to set up the database.
Part Two - Setting up a database on a web-server and then connecting to it.
The first thing you are going to need is a web hosting. If you dont already have a web hosting you can:
- Get a web hosting, Im with WebHost.Uk
- Setup a LAMP server on a spare computer running ubuntu here's a tutorial
- Use Pachube and skip this tutorial (check out this one out in stead) , this is the simplest, the service has been designed with this kind of application in mind. However at the moment from what I can tell you cant zoom and look about the graphs in any detail, but maybe this will change in the near future.
Once you have your server whether its on your local network or some ware in a far away place the next step is to set up a database to place the data we want to graph in.
Create a database with Cpanel (skip to phpmyadmin step if you don't have cpanel)
- Go to MySQL Databases
- Enter a name for your database, for example "power". Click on create database.
- Add a user to your database, create a user with minimal privileges SELECT and INSERT.
- Note down your database name, username and password you will need them again soon.
Setup database with phpMyAdmin
- Open phpmyadmin.
- Select your database from the list on the left (or create one if you didn't have cpanel to do the steps above.)
- Create a new table called DATA to with 2 fields A and B.
- On the next page, lets make the field A the field that holds the Power data and lets make the second field B hold the time. Make the power field an int(11) and the time field a bigint(20). Set Null to no and Default to None. Click Save and then Go.
- That's the database ready! The next step is to setup a perl script to access and insert values into the database.
Setting up a perl script
The perl script can be downloaded here: post.tar.gz
- Enter your database name and username in the post.pl file.
- If your using cpanel: Open file manager and locate the document root of your domain. If you have a server on a local computer locate the folder /var/www.
- Create a folder named "cgi-bin" if it doesnt exist.
- Upload the perl scrip to the folder and set its permission to 755.
- Ok we are ready to test it
- Enter this in your address bar: "http://yoursite.org/cgi-bin/post.pl?L=100&C=200"
- Now check your database in phpMyAdmin, click on Browse, hopefully you should see the values 100 and 200.
Start up the Arduino
If all is well, when you connect up the Arduino you should start seeing values being entered into your database.
Adding some basic security
At the moment anyone can enter the above address in to their address bar and add values to your database. You can make it possible for only you (your ip address) to have access to the post.pl file by creating a .htaccess file in the cgi-bin directory with the following content:
AuthGroupFile /dev/null
AuthName "cgi access"
AuthType Basic
<limit GET>
order deny,allow
deny from all
allow from --your ip address--
</limit>
If you don't know your ip address: http://www.whatismyip.com/
Part Three - Reading from the database and graphing with Flot
Screenshot of flot based graph showing the immersion heater going on
- Download Flot here.
- Upload Flot to the document root of your domain and unzip.
- Download the flot configuration file/page Graph.tar.gz this is the web page that accesses the database and creates a flot graph from it.
- Upload to the document root of your domain and unzip both index.php and layout.css to the document root.
- Enter your database name, username and password in index.php.
- Set permissions to 0644 on both files.
Great that's it! Have a look at your domain, the graph should appear! and look something like this.
How you doing guys. Greetings
How you doing guys. Greetings from Texas.
I was looking a your Tutorial and I have to say. Thank you. Thank you taking the effort and time to post and dedicate this project to all the geek around the globe!
I am currently trying to implement "flot" plotting into my project but I am getting stuck in the process.
My problem:
-Cannot get the Perl "post.pl" script to work after typing "http://yoursite.org/cgi-bin/post.pl?L=100&C=200" on the address bar
-First got error 403 "Not allowed to get access to this page" or something like this.
-Then got error 404 "Not Found"
My Setup:
Got my local computer running as my server with "Bitnami Wordpress Stack", which is a ready to install package with "Xampp" and "Wordpress"
http://bitnami.org/stack/wordpress
Main question:
Am I placing the "post.pl" file in the wrong "htdocs" folder?
or should not place it there at all?
Thank you in advance!
hi there :) i just read about
hi there :)
i just read about your project and tutorial on how arduino send the data to theMySQL.
but here, may i ask, is it possible to make the arduino to read data from the database and display to the LCD? i have problem on how to do with the sketch for the arduino to make it read the database that i create. hope you will have time to read my question.
thanks in advance.
Hey Amy Search for perl
Hey Amy
Search for perl mysql SELECT, there are a lot of good tutorials out there on how to do this. Then you could get your arduino to call the perl script as in the example above and get the perl script to send a responce back to the arduino, which you can then read on the arduino end and display on LCD.
Hope that helps
Trystan
hi there :) thanks for reply
hi there :)
thanks for reply my post.
so it will be possible to make the arduino get data from my database?
ok then, but my arduino is using C langguage.
here i have problem on how to make it read, as there need mysql.h, but i dont know how to add it up on my C
Hey Amy, the perl and mysql
Hey Amy, the perl and mysql stay on your server as in the guide above. Maybe start by getting the logging to a database above working and then I can help you with receiving data
Trystan
Thanks for reply. ok nw i
Thanks for reply.
ok nw i understand your project just now, is u need to key in the database with data.
what im trying to do is to make my arduino wishield 1.0 to read data from the MySQL i made.
i already have db on Zymic hosting. is there any idea u can give base on your experience or knowledge on arduino?is it need to do on my arduino 's C sketch ?
thanks in advance :)
Hey Amy Have a look at the
Hey Amy
Have a look at the arduino ethernet client example sketch here:
http://arduino.cc/en/Reference/ClientConstructor
If you look at that sketch you will see it does a google search and reads back the search responce to the arduino. This could be the basis for how your code works.
Create a perl file on your server that does a MYSQL SELECT from database command. print the output to the window. Similar to this example:
http://www.tizag.com/perlT/perlmysqlquery.php
Call the perl file on your server from your arduino.
Read the output of the perl file using this part of the client example:
if (client.available()) {
char c = client.read();
Serial.print(c);
Hope that helps :)
