Emoncms version + howto update
I did a RaspberryPi + HDD install following the tutorial on this website few weeks ago.
I am now wondering:
- Where can I get the installed Emoncms version? Where can I get the current Emoncms version on git (stable / beta)?
- How to update? "git pull" will update everything?
thanks
darrepac's picture
Re: Emoncms version + howto update
Any help appreciated
darrepac's picture
So I did a "git pull" in /var/www/emoncms directory... something else to do?
jonrescca's picture
Did you find the upgrading document here: http://emoncms.org/site/docs/upgrading?
I'm still on version 7, so I can't help further if you encounter any issues.
Succes!
darrepac's picture
Thanks but this upgrade page seems to be dedicated to upgrading from something to V8. I was more talking about day to day update and where to get version number + revision history
Schism's picture
If you use apt, you can look at the debian changelog for version increments (although I'm still working on a way of automatically populating this based on commit messages).
If you're using git, after you do a git pull, you can do git log --decorate to see what commits and tags you just pulled down.
darrepac's picture
hi
So doing an apt-get upgrade + git pull will update all that can be updated?
Schism's picture
apt-get upgrade won't alter any part of emoncms unless you installed it that way.
If you cloned from git, you need to change into each directory and do a git pull:
/var/www/emoncms/
/var/www/emoncms/Modules/raspberrypi (etc. etc.)
