Import data from local installation
 I had a local installation of emoncms that was recording data for a few months. Actually i t was installed on a server that i ran myself so i had a raspi sending the data remotely using the oemgateway to the server over the Internet. That method doesn't work now due to an account expiring.
im wondering if it's possible to somehow transfer that data on my own server to the account i set up on emoncms.org. That way I'd still be able to look at the data i have already gathered.
thanks!
darrepac's picture
Re: Import data from local installation
+1
Would like to do the same: from local to emoncms.org
Unfortunately there's not an easy or efficient way of doing this at the moment although I agree it would be a nice feature!
Could you use the new low write SD card image on the raspberry to view your data? you could use the backup tool to transfer the data to a raspberry.
