Data Modules
Internet connectivity
How to use the Nuelectronics ethernet shield + a simple client library and pachube exampleDescription |
Arduino Ethernet Shield + perl + mysql + Flot based graphingDescription |
An online logging and graphing platform using: Mysql + php + Adobe Flex
a project in development by Louis Beetge
Google appspot + vis Blog post and external links |
Local computer based Data , Analysis and Storage
Using KST for graphing
OpenEnergyMonitor Java based softwareA couple of java programs, one reads in data from the arduino and prints it to serial, useful for logging to a file and live graphing in kst. There is also a Voltage and Current waveform sampling program that makes it easy to see the shape of the mains AC waveform. Effectively gives you and oscilloscope. |
Display
How to add a Display
details how to add a display that has a 4 7-segment digits a mode changer to make it possible to cycle through the various values to be displayed and a frequency indicator that shows when the grid is under or above 50Hz.
How to add a Nokia 3310 LCD display from nuelectronics
This is a really cool shield, plug and play nokia 3310 LCD :)
Storage
How to add USB pen data loggingUsing the VDIP1 USB server board |
Wireless communication
Xbee wirelessHow to setup a wireless link between two arduino's, may be useful if your sensors are far away from an ethernet connection or computer.
