Emoncms v7.0 & event module [solved]
Since updating to emoncms v7.0 the 'event' module errors.
Everything else works fine.
The error received is;
Warning: Missing argument 3 for Feed::__construct(), called in /var/www/emoncms/Modules/event/event_controller.php on line 21 and defined in /var/www/emoncms/Modules/feed/feed_model.php on line 28
Notice: Undefined variable: timestore_adminkey in /var/www/emoncms/Modules/feed/feed_model.php on line 43
Fatal error: Call to undefined method Feed::get_user_feed_names() in /var/www/emoncms/Modules/event/event_controller.php on line 121
Re: Emoncms v7.0 & event module [solved]
Hello Paul, I forget to merge the redis branch of the event module into master its been merged now.
Thanks Trystan, the event module is now back working.
Best Wishes
scacchi's picture
Hi guys,
I have a problem with event, my install is Ubuntu 13.10, emoncms 7, arduino get sensor, mysql, installed redis, everything work fine (log data, publish dashboard).
I tried to install event via git but i get error when i open event, and stop to FEED Mysql (input darta still arrive well)
Fatal error: Call to a member function fetch_array() on a non-object in /var/www/emoncms/Modules/event/event_model.php on line 67
If i simple delete the folder event inside Modules all fine back like before.
Any suggestion?
Am i wrong about install redis-server?
Did you run the database updater after installing the module? it may be that.
scacchi's picture
I dont know how do that...
If i open localhost/categories/admin i see a white page with black top line input feed .....
nothing to "admin"
The database updater is located localhost/emoncms/admin/view
Log into your web page, Admin button 4th from menu top right, then Update Database.
ngbod's picture
If admin is still not visible log out and back in and it will appear.
scacchi's picture
I solved with the help of  Trystan, old post of 2012....
problem was a double account in MYSQL with same name and pwd, so i didn't notice i logged in with another account.
So i recreate DB and check the first account create if has the FLAG ADMIN to 1 inside DB Mysql and appeared again the admin link, update the DB with event installed and done...
 FEED and DASHBOARD to do again but... like i always say..."was so ugggggllly..." i will do better looking..ahahahh...
Thanks guys...
Wait another issue...
when i go inside EVENT SETTINGS
Fatal error: Call to undefined function mcrypt_decrypt() in /var/www/emoncms/Modules/event/event_settings_view.php on line 24
below the password field...
but i think i will go to check the module inside the event...
Have you installed php5-mcrypt as per the readme?
scacchi's picture
Yes Sir...
Already updated to the newest version....
Maybe i need to check if is used or not..
Alex
scacchi's picture
Paul...
you are right....
actually was installed php5-mcrypt but in my system was not inside the mods-available of php5,
i notice with the command:  sudo php5enmod mcrypt   (if someone else will get the same problem)
i moved the file inside mods-available and for now looks everything fine.
Any other module interesting to install?
Thanks Paul !!!!
Alex
scacchi's picture
Well... another one...
I set some event, but no mail and always FALSE the condition, i see now that FEED well but the dimension is always 0
When i try to update the db i receive that error
Call to a member function fetch_object() on a non-object in /var/www/emoncms/Modules/admin/update_class.php on line 64
Im sorry for bother but i really cannot solve that...
thanks a lot...
Alex
unique24's picture
Hello!
Please can you describe how to fix? Have the same problem and don´t know what you moved.
Thank you!
