Using KST for graphing
In the last year of my physics degree I did some work for the physics department developing a sun tracking sensor for a balloon based telescope. I got to use a great piece of free and open source graphing software called KST. Its a program designed specificely for plotting large amounts of scientific data. From the KST website:
"Kst is the fastest real-time large-dataset viewing and plotting tool available and has basic data analysis functionality. Kst contains many powerful built-in features and is expandable with plugins and extensions. Extensive help is available, both from within kst and on the web. Kst is a KDE application and is freely available for anyone to download and use."
Its a great program to use to plot energy monitor data. Here's an example of data being plotted from the non-invaive current trasformer method:
How to install on Ubuntu
In a terminal window type: $ sudo apt-get install kst
On windows
If your a windows user kst can be downloaded here: http://kst.kde.org/download.html
How to start graphing
- First you will need ArduinoComm which is detailed here.
- Run the program with $ java programName >tmp.dat. The addition of >tmp.dat at the end of the run command line writes the data outputed by the java program to a file for storage.
- Run KST by typing $ kst
- Once KST is open click the magic wand button: the data wizard.
- Find your tmp.dat file and click next
- Move all available data Fields to the selected data field box by clicking the right arrow.
- Click on the 'Next' button.. and again...and then 'Finish'
- You should now see several graphs are in the above picture and they should be updating in real time!
Pictures and Screenshots
Here's screenshot of a typical output with two lamps and a laptop connected using the mains AC non-invasive method (click to enlarge):
36 hours of whole house electricity use monitoring:
the above zoomed in a bit over a few hours.
Whether it will work from
Whether it will work from RS232 serial port...
May do not sure...
May do not sure...
