kWh/d starting in middle of the day
my problem is the day for my kwh/d feed is starting in the afternoon? about 3pm i think.
My dash board is emoncms.org/goldpower
Any ideas on how to fix this?
Cheers sam
Re: kWh/d starting in middle of the day
What is your timezone set to?
goldpower's picture
UTC+12 as I live in New Zealand
thanks
In that case it's probably one for Trystan. Having the TZ not set is usually the reason for things like that being wrong.
goldpower's picture
Thanks for your help Robert
nerdy's picture
I am having this problem also. My timezone is set for Brisbane/Australia UTC +10 but my kWh/d aggregates reset each day at 10am my time. I change my timezone on Emoncms to UTC +0 and my kWh/d values are correct but my GLCD time is out by 10 hours.
http://emoncms.org/Nigel
nerdy's picture
Any ideas Trystan?
I have my timezone set correctly in http://emoncms.org and my GLCD shows the correct time and resets the kWh/d correctly. It's just the kWh/d value on emoncms.org. Mine resets each day at 10am local time.
Is it a problem for people that are on the + side of UTC in emoncms.org?
Yes your quite right, this has been a bug for some time. The new timestore feeds which have in build averaging and calculation of kwh/d via the timestoredaily visualisation solves this for timestore feeds but yes it would be good to solve this problem for mysql based feeds.
nerdy's picture
Would it fix it if I moved the feeds to timestore?
Existing data would be corrected?
Yes all new data would be recorded/displayed correctly if you updated to Timestore.
Existing data will also be converted to Timestore.
The timezone is correct after conversion for timestore feeds visualized with timestoredaily, including historic data, I can convert your phptimeseries feeds to timestore if you wish Nigel?
Nice dashboard you have there too!
nerdy's picture
Go for it Trystan.
Is there any downside. I am about to order the RPi kit to replace my emonBase. Can I still export the data from emoncms.org to my own emonsmc?
nerdy's picture
Hi Trystan. Just a polite bump.
If there is a way I can do it let me know.
ewiandr's picture
G'day,
How do I convert my phptimeseries feeds to timestore, on emoncms.org ?
Andy
ewiandr's picture
From reading various post it seems that timestore is not used anymore?
Do you have a fix to allow the daily data to use the local time instead on UTC/GMT.
For emoncms.org and/or localhost server?
My timezone is set correctly (UTC +10)
