Enomtx shield
OK , Yesterdays I bought a EmonTX shield for my ardunio uno r3 connected to An ethernet shield , I maybe Missing Something here , once I get the shield and have everthing  Soldered Can I send the data to enomscms via the ethernet connection or do I need something else
Wxll's picture
Re: Enomtx shield
You need to get the sketch form the git:
https://github.com/openenergymonitor/nanodeRF
And probably adjust it so it matches the Arduino with Ethernet shield.
Can be doable I guess :-) I've unfortunately no experience with the Arduino but it must be pritty close to the NanodeRF.
Wxll
