Multigraph automatic update
Hi @all emoncms friends,
Is there a way to update the Multigraph dynamically? Maybe via the vis_slowupdate() function?
Tried to call vis_Draw() function but had no success.
jonbev's picture
Re: Multigraph automatic update
Could you refresh the iframe on a timer?
D.Schmidt's picture
I don't want to update the whole iframe, because when I have already zoomed into the Multigraph, on every refresh (in my understanding) the Multigraph would be set back to default view. Any other ideas?
D.Schmidt's picture
I got it. Inserted in function multigraph_init() an Interval with setInterval(function () {inst_refresh(); vis_feed_data();},time);
In inst.js I declared a new function inst_refresh()
 { var timewindow = (end-start); timeWindowChanged = 0; }
That works fine for me.
engeeaitch's picture
Hi - I am interested in doing this as well.  I tried your solution, but it didn't work for me.  Could you post the modified files somewhere please (or a snippet so that I can see exactly how to insert the code).  Many thanks.
D.Schmidt's picture
There are two files you have to modify:
  • Modules/vis/visualisations/common/inst.js
add this function:
function inst_refresh() { var timewindow = (end-start); timeWindowChanged = 0; }
  • Modules/vis/visualisations/multigraph.js
Look for "function multigraph_init(element)" and add following snippet to the very end of it:
setInterval(function () {inst_refresh(); vis_feed_data();},20000);
To make sure you get it running I attached the modified Files.
o_cee's picture
D.Schmidt: Would it be possible for you to submit this as a pull request on GitHub? Would be nice to merged to the main branch for everyone to use?
elyobelyob's picture
I'm finding (by looking at firebug console), that it is calling the same data e.g. feed/data.json?&id=2&start=1360847478146&end=1360933878146&dp=400 .. so, the start and end times aren't changing .. I still need to hit a menu D to update the data.
darrepac's picture
Is there something working to make the multigraph to refresh automatically without losing the current zoom?
zaxter's picture
@darrepac I'm looking for exactly the same thing! Did you find any solution yet?
zaxter's picture
I'm looking for the exact same thing. Anyone found a solution yet?
I tried D.Schmidt's solution but it didn't work as I wanted it to. :(
zaxter's picture
This is for anyone who wants an auto updating multigraph that pans right periodically in zoom as well.
I borrowed @D.Schmidt's solution (from above) which although automatically updates (redraws) the multigraph, it doesn't pan-right periodically when zoomed. I thus added a bit of my own code to get the periodic pan right in zoom.
Please forgive my rather crude and inelegant approach (given that this is my very first attempt at js) but it works for me. :)
1. First add the following functions to Modules/vis/visualisations/common/inst.js:
function inst_increment()
    var laststart = start; var lastend = end;
    end = (new Date()).getTime() - 30000;    //sets the updated end time to 30 secs behind the current time,
    var timeWindow = (end-start);
    var shiftsize = timeWindow * 0.01;
    start += shiftsize;
    end += shiftsize;
    timeWindowChanged = 1;
And->
    inst_increment();
2. Then add the following at the very end of the multigraph_init() function in Modules/vis/visualisations/multigraph.js:
setInterval(function () {inst_refresh(); vis_feed_data();},10000);
3. You may want to add a button which when pressed will automatically zoom to the required time frame and begin panning right periodically. For eg. if you wanted something similar to the 'D', 'W', 'M' buttton for hours or minutes, you can add something like this:
"<button class='btn time' type='button' time='0.01'>Set</button>"+
Playing with the hardcoded values, one would be able to adjust the time window and refresh rate.
Thanks.
micha's picture
Hello zaxter,
it doesn't work at all. The SET button works, but there is no automatic update of the multigraph. Should happened every 30 s, isn't it?
I like to update the graph every 5 s. Is this possible?
Thanx, Micha.
