mounting emonth outside
Is the emonth able to be mounted outside, if it's out of the weather? I have a location where I can mount the emonth that will still get good air circulation but not be in the weather. Will this work, even if the outside temperature gets below 0 deg F (in which case I should use Lithium batteries)? Will the circuits still work at low temps?
Re: mounting emonth outside
Have you looked at the hardware Wiki? Provided the atmosphere is non-condensing, I think, while I haven't checked every single component and except for the batteries, you should be good to -40 °C.
