REDIS configuration
I've got a Brultech GEM that I've had posting to smartenergygroups. Now that SEG has started charging an arm and a leg, I'm looking to move to a self hosted setup, so I've been setting up emoncms on a Raspberry Pi 2.
I followed the directions here to get things set up: https://github.com/emoncms/emoncms/blob/master/docs/RaspberryPi/readme.md
My watt inputs seems to be working correctly, but watt hours, not so much. I gather that I need to use the Wh accumulator, but that is disabled because REDIS isn't enabled. I tried enabling REDIS in settings.php, and my feeds broke horribly (existing feeds all disappeared, new feeds failed to be created, the feed list couldn't even load). I assume I need to perform some sort of configuration of REDIS, but I can't find any documentation as to what. Can anyone give me any guidance on what to do here?
Re: REDIS configuration
Hello Zhentar
Are you able to access redis-cli from command line?
$ redis-cli
if so you could try clearing the redis database with:
$ redis-cli "flushall"
If that doesnt sort it but you can access redis then perhaps its an issue with the redis php client..
Zhentar's picture
The flushall seems to have fixed it. Seems odd that it would be needed on a fresh install, but whatever. Thanks for the help!
