emoncms v9.3 with emonhub: Feedid # does not exists or was deleted
Last night I installed a fresh copy of emoncms v9.3 with emonhub and am testing with emonTH. I see a node 23 with 7 inputs, temp and humidity are looking good.
Now I'd like to make a feed and push the wrench button, do: log to feed, data: realtime, create new, phpfina and hit Add.
After a bit I get an error message: Feedid 21 does not exists or was deleted...
(The typo with 'exists' actually is visable...)
So I check the lib/phpfina/ directory and actually do find the 21.meta and the 21.dat files exist and have the following rights:
-rw-r--r-- 1 www-data www-data  16 Feb  7 13:45 21.meta
-rw-r--r-- 1 www-data www-data 548 Feb  7 14:08 21.dat
data does go into the .dat file since it grows in size.
Since emoncms doesn't find the files I guess I can't pick up a feed and send it to a graph.
Running on raspi Jessie on a Raspi2B, installed as per instructions mentioned on the site.
Any suggestions?
Cheers, Ruben
ajsicek's picture
Re: emoncms v9.3 with emonhub: Feedid # does not exists or was deleted
Hi Ruben,
did you manage to find a solution? I am having the same issue :)
Cheers
ajs
