Base topic for emoncms 9.3 as MQTT subscriber
In the documents here https://github.com/emoncms/emoncms/blob/stable/docs/RaspberryPi/MQTT.md
it says:
emoncms as a subscriber
[basetopic] and user ID of the target Emocnms account can be set in settings.php. Default basetopic = emon,
Is this true or do you have to set the base topic in settings.php? If so what is the format as I see no mention other than:-
// The 'subscriber' topic format is rx/* - where * is the emoncms input node number.
I have tried emon and rx and my setup does not seem to be subscribing to either topic. Using version| 9.3 | 2016.01.26 just updated with a git pull.
I have checked that these topics are being actually published with a different application.
Ian
borpin123's picture
Re: Base topic for emoncms 9.3 as MQTT subscriber
I think the docs have been updated. Have another look.
cheers
