EMONCMS V9.3 Authentication
Since upgrading to V9.3 from V8.5 low write I seem to get a lot more login prompts, particularly when switching between WiFi and Cellular on my iPhone. Is there any possibility of adding a authorised devices function or adding a no security on local lan option?
chaveiro's picture
Re: EMONCMS V9.3 Authentication
Check V 9.31 it should be fixed.
sheppy's picture
Thanks Chaveiro for your continued hard work,
Now if only I could create new feeds I'd be a happy man!
sheppy's picture
Now the feed creation bug has been fixed I've given this a thorough test and it works very well. Authentication is needed a lot less often, thanks very much Chaveiro
