NOOB - openenergymonitor without Emonglcd but with an android tablet?
Sorry, have done a search but can't find what I'm looking for...
I'm hugely interested in monitoring my home electricity consumption and (PV) generation with openenergymonitor. Thing is though that I would like to use the system without the LCD, using an android tablet instead. Is it possible to do this? The tablet would simply display an Emoncms dashboard. I am not sure though if the entire system will be crippled by not having the LCD screen. I've read somewhere that the kWh/day is calculated in the LCD and that it also logs the interior temperature. Would I be able to also have a kWh/day readout on Emoncms without havind the Emonglcd?
Thanks!
Sebastiaan
Lloyd's picture
Re: NOOB - openenergymonitor without Emonglcd but with an android tablet?
You certainly can build your system without the LCD display - the only thing that you will lose is the internal room temperature.
Basically emontx is used to read consumption, and this is transmitted to emonbase (for upload to emoncms) and/or emonlcd (for display).  The server software (emoncms) does the per day calculation for the web based display, and emonlcd does it own calculation for its own display.
Lloyd
sebastiaan's picture
Thanks! I guess I could use a temperature sensor on the TX to log the interior temperature as well?
Yes, no problem.
mikerowland's picture
Yes, you can do almost anything you can think of...
I have a similar plan to use an Android tablet for display in the kitchen - see my dashboard here and link to build details...
Good luck
