Emoncms on user login returns "undefined "
Hello!
installed emoncms system of Windows 8 with wamp server . Everything ok, rewrite_mode activated . When I go to register a new user on the main page of emoncms, emoncms stops writing in red "undefined ". Php.ini is ok as the installer guide.
Anyone have any ideas ? I tried searching the forum but without success. The proposed solutions do not work
I hope it was wrong to seek ...
Thank you!
F.
Re: Emoncms on user login returns "undefined "
A good starting point is checking your browser's 'developers mode' - usually F12 starts it, and look for any errors highlighted. I don't use emoncms on Windows, but I've seen similar errors occur in Raspbian with php 'sessions'.
fvolpato's picture
Hi Paul!
The browser answer:
Synchronous XMLHttpRequest on the main thread is deprecated because of its detrimental effects to the end user's experience. For more help, check http://xhr.spec.whatwg.org/.
http://xx.xx.xx.xx/Lib/jquery-1.11.3.min.js Failed to load resource: the server responded with a status of 404 (Not Found)
This is the error. xx.xx.xx.xx is my public ip.
Thanks.
F.
chaveiro's picture
Synchronous XMLHttpRequest is a warning.
The 404 is an error, can you access that file directly? If not, its bad instalation.
fvolpato's picture
Hi!
Yes, i access.
Maybe is a wamp configuration? Or some file of wamp?
I have do two times installation....
F.
fvolpato's picture
I not have idea... :-((((
F.
jonrescca's picture
This happens here too on a fresh install, since it's missing the /user/register.json
jonrescca's picture
I found that the .htaccess file was not copied with the downloaded 9.2 files from the zip, try adding it to your emoncms root from here: https://github.com/emoncms/emoncms/blob/stable/.htaccess
jcgonzales's picture
After installing emoncms on an 1&1 shared server, I experience exactly the same, unless there is a specific default user and password, I cannot register a new user, and as fvolpato I get the following message even though I have refreshed the .htaccess file with the content of the one suggested ; by the way the .htaccess already existed.
Thank you for your help
[Please don't post multiple copies - see "Read this before posting". Also, please add your image to your post, because an image linked on a 3rd party site can disappear, and that helps nobody. See "Adding a picture to a post" to find out how. I've deleted the copies. Moderator (RW) ]
           I apologize, I tried several times because my post did not appear, thanks for your help
The problem is now fixed, at least for a shared server located at 1&1, the rewrite syntax was not correct In the .htaccess file :
As the .htaccess is located in a /emoncms subdirectory, the rewrite must specify the subdirectory name :
# Various rewrite rules.
<IfModule mod_rewrite.c>
  RewriteEngine on
  #RewriteBase /sites/emon/
  RewriteBase /emoncms/
fvolpato's picture
Hi to all. Solved!
I followed the advice of jcgonzales in the previous post and I solved the problem .
Thank you!
F.
rubenlaan's picture
I have the same issue with version 9.3 on the latest build on Jessie, edited the .htaccess file as above to no avail. Absolutely clueless here...
Cheers
Ruben
