EmonCMS 9.2 , Event Module problem..
I tried to install the event module on my system ( Emoncms Version low-write 9.2 | 2015.11.27 ),  following the steps outlined here:
https://github.com/emoncms/event
After installing the module I proceeded to press the "database update" button.
It happens something very strange .. when I try to insert an event, many of the data feed (not all ..) stop being updated.
To restore feed updates i have to proceed with one of the following actions:
- Cancel the event was added, or
- Rename the event directory ..
Any idea?
Fabrizio..
Re: EmonCMS 9.2 , Event Module problem..
Unfortunately the events module is no longer compatible since the v8.5 changes see Events module and emoncms compatability for more info.
