Emoncms.org account has partially frozen. Server error?
Since 2 am on Friday my emoncms account has stopped showing data from 90% of my inputs. In the inputs page it is saying  " -1303619814s ahead (set clock) " on the affected nodes. Strange that some of the nodes are getting through and recording correctly.
I have checked emonhub debug log and the sends are receiving an OK from emoncms.org and no errors are being recorded. I then set up a new emoncms.org account and changed the write API in emonhub to the new one and the data from all my nodes showed up correctly.  I think this means there is a problem with the emoncms.org server with my proper account. Is there anything I else can do to check this?
Re: Emoncms.org account has partially frozen. Server error?
Sorry should be fixed now, its caused by a reoccurring error with the input limiters on emoncms.org. I've cleared all the limiters on your account so should be back to normal for you now.
nrgbod's picture
Thanks Trystan, it's working again now.
nrgbod's picture
Trystan,  my nodes have stopped updating again. One set of nodes are displaying   -1303182586s ahead
(set clock)  and the rest are showing as last updated 3 days ago.  Is this due to a problem on emoncms.org server?
It could be a problem at my end but I can't access my server until the weekend.
I think this one might be an issue on your server. I think the one node with -1303182586s has not been updated since I cleared the input limiters.
nrgbod's picture
Trystan, thanks for checking it out.
I've lost remote access to my network since changing ISP so must sort that out at the weekend as well !
