input - input = feed
This is properly a really easy thing to do but i can't seem to work it out
i have two kWh/d inputs
5.1 Grid Power
5.2 Solar Power
i'd like to subtracted the Solar Power from the Grid Power and then output the result to its own feed to use in a dial
Grid Power - Solar Power = power balance
can anyone help me do this
Thanks Steve
smitt1979's picture
Re: input - input = feed
Its OK worked out a way to do it
Beire's picture
How did you do it?
smitt1979's picture
i updated to emoncms 9.2 then add a new virtual feed
i used the +feed and add Grid Power then a -feed for Solar Power
see image
Steve
Can't see the screenshot very well...
smitt1979's picture
Better image
