v9.1 update kwh/d
I've just updated to v9.1, during the update my kwh/d feeds al reset to 0.
They restarted counting again. But today just restarted from 0.
Is there a way to rebuild them from the accumulated kwh feed?
Also i have a few feeds that turned negative during the DST period.
Can i fix these DST faults?
Re: v9.1 update kwh/d
Can you confirm that you mean kWh/d  and not the kWh feed.
Its normally the kWh feeds that are affected.
Beire's picture
I can yes.
I have 2 of these feeds. One is an electrical power input (W) processed by a "power to kWh" processor followed by a power to kWd/d process.
The accumulated graphs show no dip at the time of update.
The power to kWh / d graphs were reset to 0.
When i export the data from today of the accumulated kWh, i can calculate the kWh/d myself and manually add them?
Yes, go to Extras>Visualization and select 'Edit Daily'.
You should then be able to edit the bargraph to the correct figure.
Beire's picture
Allright. Thx paul.
In the screenshot you can see the dip caused by the DST bug I the kWh graph.
Is there a way of fixing this?
Also, is this supposed to always happen in the future when updating versions?
We now have only 2 accounts using our Serer. But in the future j can't see me updating everyone manually. :)
Hopefully not!
A lot of things changed between v8 & v9, including the way emoncms handles timezones & timestamps, so it was inevitable that there would be a few minor issues.
Beire's picture
OK. Good to know :)
