EmonTH powered by power supply
Is it possible to power the EmonTH by a 5V mains supply rather than battery?  I want to run a number of temp sensors and an optical reader and I suspect the batteries would run down a bit quick and TBH I don't want the hassle of changing them!
If so is it something that can be done before dispatch?
Brian
Re: EmonTH powered by power supply
If you want a screw terminal block soldered in, where you can feed in 5 V, (which I think is not fitted as standard), you need to email the shop.
