My jump to Emoncms V9
So as recommended i create a new thread
And i have followed https://github.com/emoncms/emoncms/tree/9.0/docs/RaspberryPi VERY CLOSE
at the step where you should click update database i did
but before i move on to emonhub i check if i can create a dashboard and put something on it... And like before i cant
Since V9 is so new a search in the forums did not turn up anything i could use... will keep looking thou
EDIT: 3rd last post in this one is the same problem http://openenergymonitor.org/emon/node/11461
i run on chrome thou
Re: My jump to Emoncms V9
Have you tried a different browser, such as Firefox?
can you describe in more detail what the problem is,
boelle's picture
the problem... when i go to dashboard i first create one of course.... but then there are no buttons to add text etc etc
screenshot added as pic
will try internet exploder also
boelle's picture
baaaah, works in internet exploder....
but why not in chrome?
boelle's picture
to make it even more strange if i hit F5 in chrome it works too
i guess i can move on now
Oh good.
boelle's picture
btw... for this next command:
git clone https://github.com/emonhub/dev-emonhub.git ~/dev-emonhub && ~/dev-emonhub/install
i should be in home dir right?
any clue why dashboard needed a F5 in exploder and chrome to work?
Yes, although it shouldn't make much difference.
Because the previous version's code was cached in your browser.
boelle's picture
oki, well emonhub started ok too...
so it beats me what went wrong... i did excatly as before... and yet there was a difference in the outcome
time to order a funny jacket and padded room :-D
boelle's picture
Something i want to add... and i have looked near and far on this...
a button near my hot water widget that i can use to heat up water should i need it at odd hours.
i pretty much have an understanding on how the sketch at the emontx should be...
what puzzles me is how to make the button alter the value in the packet gen page...
that raises the next question... where did packet gen go in V9 ?
boelle's picture
Will packetgen come back? and will there be a small guide on how to create a button etc so we can turn heating etc on and off from dashboard?
i know there is a link for how trystan(or was it glyn?) but that was done by directly editing the packetgen value when logged in... and not much telling on how it was done with a complete guide
