kWh/d inactive after update 9RC2
I use Emoncms for one year and I find it very nice …
I use the version V8.3.2 (install with apt-get) of a Raspberry … Yet I do the update of the version 9 RC2 | 2015.09.15
The feed” kwh/d” work normally in the version V8.3.2., since the update, my feed kwh/d are inactive … The DataType of my feed PHPTIMESERIES and PHPFINA.
All the others feeds work normally in the new version … Can you help me?
Thanks,
Re: kWh/d inactive after update 9RC2
I'm currently using version v9.1 2015.11.02 and the process works fine here.
zeppy14's picture
Thanks for yo repply,
I test the new version  9.1 | 2015.11.02 but it don't work for me  ... I have the same problem ...
zeppy14's picture
I try with the version 8.5.2 | 2015.07.20 ... all my feed are Ok.
What must I do to have the feed "kwh/d" in the new version 9.X ?
What have you tried to fix it? Have you checked your emoncms log,
What happens if you create a new feed based upon the kWh/d processor
zeppy14's picture
With the version 9RC2, I make a new database with only one input who was increment with a jon request. Of this input I take two feed  : "log to feed" and "kwf to kwh/d".
The feed "log to feed" is active and I can see the value ... the feed  " kwf to kwh/d" is inactive and I have not value.
As per my previous post, have you checked your emoncms log?
Also check your folder/file permissions for your Phpfina data folder.
zeppy14's picture
I check the emoncms.log. I find no entry of my “Kwh to kwh/d” feed …
The log to feed => the Phpfina feed  are update
The kWh to kwh/d => the PHPTIMESERIES feed are inactive.
I check the permission:
24580 drwxr-xr-x  2 www-data root     4096 Nov  7 07:41 phpfina
 24579 drwxr-xr-x  2 www-data root     4096 Nov  7 08:05 phpfiwa
 24581 drwxr-xr-x  2 www-data root     4096 Nov 10 08:46 phptimeseries
PS : Sorry for the late response
zeppy14's picture
My Config :
Emoncms Version 9.1 | 2015.11.02
Server OS Linux 3.4.103
Host bananapi bananapi (192.168.0.20)
HTTP Server Apache/2.4.10 (Debian) HTTP/1.1 CGI/1.1 82
Database Version MySQL 5.5.44-0+deb8u1
PHP Version 5.6.13-0+deb8u1 (Zend Version 2.6.0)
Modules Core   date   ereg   libxml   openssl   pcre   zlib   bcmath   bz2   calendar   ctype   dba   dom   hash   fileinfo   filter   ftp   gettext   SPL   iconv   mbstring   session   posix   Reflection   standard   shmop   SimpleXML   soap   sockets   Phar   exif   sysvmsg   sysvsem   sysvshm   tokenizer   wddx   xml   xmlreader   xmlwriter   zip   apache2handler   PDO   curl   dio   json   mcrypt   mysql   mysqli   pdo_mysql   redis   mhash   Zend OPcache
Larsjo's picture
Have the same problem, the kwh/d do not update.
Did you find the problem?
Chaveiro committed a fix for 'Fix kwh on emoncms update' a few days ago which has not been merged to the v9.1 branch as yet, but is merged to the 9.x branch.
But don't think it will sort your issue, as I think that it was a fix for the 'power to kwh' process feed dropping in value on update.
So just to recap, have you;
  • Selected your correct time zone in Setup > My Account
  • Updated your database in Setup > Administration
  • Created a new settings.php file from default.settings.php when you updated
  • Checked the 'input' process list for that feed to make sure that all looks good
zeppy14's picture
No I have not solution to this problem ... for yet I use my old version V8.3.2 !!
To Paul : I will test the 9.x again ...
But during, my fisrt test, I have make this action :
Selected your correct time zone in Setup > My Account                                 YES
Updated your database in Setup > Administration                                           YES
Created a new settings.php file from default.settings.php when you updated      YES
Checked the 'input' process list for that feed to make sure that all looks good    YES
I will change my version from Emoncms Version 9.1 | 2015.11.02 ... but Paul what is exactly the version I must test ? (have you the good link?)
9.1 is the current stable release, 9.x branch is a development branch which contains the latest fix from Chaveiro.
Larsjo's picture
Think i got it all set.
Used the default.setting.php from 9x copy to setting.php edit with path and sql info
zeppy14's picture
I test install the 9x
Selected my time zone in Setup
And it doesn't work ... my feed are inactive
I've just installed emoncms v8.5.2 from scratch on a second pi, and want to build up the feed data for a while before updating it to v9.0 later this evening. I'll report back how it goes, and document the steps taken as well.
Hhhm, not gone as planned! There are issues here (but you know that!)
zeppy14's picture
I make my update step by step …
So I test all versions from 8.3.1 to 9.
My graph Kwh/d work normally in the version :
                8.3.1
                8.3.3
                8.3.6
                8.4
Every day, I change the version and if all is Ok, I make the update of the next version …
Today I will check the version 8.5.
I will post the result of my test …
Stephane, did you see my update post http://openenergymonitor.org/emon/node/11636
zeppy14's picture
Thanks, I have look it ...
Today, I test the version 8.5.2 | 2015.07.20 and all mind Ok.
So for the next update to the version 9, I will use your process.
zeppy14's picture
I have update my Emoncms to 8.5.2  ... all war feed are OK
And today I test your update from 8.5.2 to 9 (post http://openenergymonitor.org/emon/node/11636) but my feed "kwh/d" are inactive :-(
I find nothing in the log ...
Inactive, or have they reset to zero?
zeppy14's picture
Inactive !!
zeppy14's picture
See this screenshot !!
