regenerate kwh data
Help!
I upgraded to version 9 rc2 from git. Since then my kwh data reset back to zero.
New data is adding correctly and as expected now increasing again - a nice sawtooth pattern.
Is there anyway to recreate all the data by processing the raw "feed to log" data - both are phpfina's
I also need to do the same for all the subsequent data feeds
Any thoughts?
Re: regenerate kwh data
Yes I had (have) the same problem...
Trystan commented about this here, but it didn't work for me.
However, my 'feed to log' was phpfiwa, so please let us know if it works for you.
octagon's picture
The other wrinkly is that if I use the "live" feed view and zoom out to the "hour" view
i get no data.. just blank - any fixes ?
I'll try trystans re-generation script later. Hopefully there's similar for the kwh/d and the histograms...
octagon's picture
Running the process script and it chucks out a few errors
Warning: unpack(): Type f: not enough input, need 4, have 0 in /var/www/emoncms/usefulscripts/process/Lib/PHPFina.php on line 320
PHP Warning:  unpack(): Type f: not enough input, need 4, have 0 in /var/www/emoncms/usefulscripts/process/Lib/PHPFina.php on line 320
Will let you know how it finishes..
...this is an issue that really could do with sorting.
For example, below is my 'Power to kWh' feed, and as you can see, everytime there is an interruption to the network, the accumulative totals drop - meaning negative values in 'my power' and a distorted view of imported power.
octagon's picture
yeap that looks like mine - but i only have 2 drops - last time the clock changed and this upgrade.
But I'm running it all locally so the "network" is only from the emontx to the raspberry.
the processing seems to be taking a while so I'm testing the time it will take over night. do the proper fix tomorrow...
Any ideas on the zoom out issue - its really annoying not getting the "hour" view. Is it because its a fina and it should be a fiwa ?
octagon's picture
Paul - the network interruption is that on the original log to feed and the impact of that is being felt in the output of the power to kwh?
Does the log to feed get upset when there is no data for a given timestamp? is it a fixed time data record type issue? my initial log to feed is a REALTIME / PHPFINA data source - what's yours?
Perhaps the other question is - what should it be ?
The network interruption is where I've unplugged to ethernet cable, disconnecting the Pi from the LAN (my router only has 2 ethernet ports - one is used for VOIP full time, and the other I've needed to occasionally share with another project I've been working on). The dips seem to coincide with when the LAN is disconnected.
The original log to feed is a realtime phpfiwa feed, and that looks completely normal, with no changes whatsoever when the 'power to kwh' feed shows the dips.
This is more a minor annoyance for me, hence I haven't looked too far into it, however to others it could present a considerable issue if that data is important.
octagon's picture
is your Pi reporting the data across to a remote emoncms then?
Mine is doing it all locally - hence less issues i guess.
I'm sure that the power to kwh will have a knock-on impact on the kwh/d process and the histogram's that i'm running as well. Yes for me the data is important - using it to build a case to get an battery to increase my self-consumption...
PS you can get a network switch to solve your 2 port issue ;-)
I'm not reporting to a remote emoncms, just need the LAN connection for apache to serve up the website.
If I run the script (just tried again), I get;
pi@raspberrypi ~/usefulscripts/process $ sudo php power_to_kwh.php
Power to kWh processor feed 14 -> feed 41
Recalculated in 71s
And the graph looks exactly the same.
octagon's picture
71s? What are you running it on?
mine hasn't finished yet.
So a regeneration won't fix it - probably related to all the errors
The issues must be in the source data - or how the missing data is being handled
who knows most about that PHPFina.php code?
I've implemented what I think should be a fix for the error on line 320 of PHPFina, but I dont think this is the cause of the larger issue. Can there be a large negative spike at that point in the power feed?
It may be possible to get around this issue with an extra line after line 67: https://github.com/emoncms/usefulscripts/blob/master/process/power_to_kw...
if ($kwh_inc<0) $kwh_inc=0;
but ideally it would be good to know whats causing the large negative $kwh_inc values
Mine runs from a powered hub, which also powers the USB HDD too.
Whenever I shut down the pi, I always use sudo poweroff, and ensure that it's completed it's shutdown before removing the power.
So no idea where the spike is coming from.
Didn't you experience the same issue when you installed v9 too.
octagon's picture
trystan - thats  not fixed it. I added an extra line of debug ->
            if ($last_time && ($time-$last_time)<7200)
                // kWh calculation
                $time_elapsed = ($time - $last_time);
                $kwh_inc = ($time_elapsed * $power) / 3600000.0;
                if ($kwh_inc<0) {
                        print "Weird low spike power =  last time=$last_time, time=$time, power=$power, kwh_inc = $kwh_inc\n";
                        $kwh_inc=0;
                $kwh += $kwh_inc;
but that debug never appears - but still getting the same error.
Adding some more debug its actually the read
    while ($dp = $engine[$source_engine]->readnext($source))
that is throwing the error. (added debug at the beginning and end of the loop...)
@Paul I think that was a separate issue to do with existing power_to_kwh feeds, my solution was to recompile using the script?
@Octagon, what error exactly is while ($dp = $engine[$source_engine]->readnext($source)) throwing. It's not using the lastvalue function in which "Warning: unpack(): Type f: not enough input, need 4, have 0 in /var/www/emoncms/usefulscripts/process/Lib/PHPFina.php on line 320" originated?
octagon's picture
Notice: Trying to get property of non-object in /var/www/emoncms/usefulscripts/process/Lib/PHPFina.php on line 422
PHP Notice:  Trying to get property of non-object in /var/www/emoncms/usefulscripts/process/Lib/PHPFina.php on line 422
the read is now responsible for that above !
Seems we have moved the target.
octagon's picture
Ah that one was my bad. I'd copied the original feed I wanted to process so that emon could continue running, But i'd not done the meta data...
Now my debug is working I get output like :
Weird low spike power =  last time=1405761350, time=1405761360, power=-113, kwh_inc = -0.00031388888888889
Weird low spike power =  last time=1405761360, time=1405761375, power=-87, kwh_inc = -0.0003625
Weird low spike power =  last time=1405761375, time=1405761385, power=-68, kwh_inc = -0.00018888888888889
Weird low spike power =  last time=1405761385, time=1405761395, power=-86, kwh_inc = -0.00023888888888889
I produce a chunk of electricity from the PV. My graphs can go "negative" because of the amount i pump out...
octagon's picture
careful timing caught this :
Weird low spike power =  last time=1409501355, time=1409501365, power=-28, kwh_inc = -7.7777777777778E-5
Weird low spike power =  last time=1409501365, time=1409501375, power=-20, kwh_inc = -5.5555555555556E-5
Weird low spike power =  last time=1409501395, time=1409501410, power=-6, kwh_inc = -2.5E-5
Weird low spike power =  last time=1409557125, time=1409557135, power=-7, kwh_inc = -1.9444444444444E-5
Weird low spike power =  last time=1409557135, time=1409557145, power=-7, kwh_inc = -1.9444444444444E-5
octagon's picture
well it ran - now looks as if something had eaten a small slice !
Going to re-run without the kwh_inc resets and see what happens.
octagon's picture
OK the graph looks better now.
Now when I'm exporting it does what I'm expecting - not add it onto the consumption :)
still annoying to get those huge "anti-spike"s in the data
