Possible to change feed engine interval on emoncms.org?
Hello folks, It's been a while but I now have a TX, GLCD and Nanode all working together. I've been successfully uploading data to emoncms.org over the last few months and this has been working fine - however, having got my head around the feeds and inputs, I was wondering whether it's possible to retrospectively change the feed engine (type or interval for example) on any particular feeds? I can't seem to do this through the UI or indeed find any information on whether this is possible? The only workaround I can see is to create a new feed id with the amended engine but then I'd lose the historical data :(
Any help appreciated!
Re: Possible to change feed engine interval on emoncms.org?
I don't think it's possible - see the explanation of how the feed engines work:
https://github.com/openenergymonitor/documentation/tree/master/BuildingB...
