fail pecl.php.net swift/swift
I tried again to do a clean install of emoncms and always came to the same error in step:
sudo pear channel-discover pear.swiftmailer.org
sudo pecl install channel://pecl.php.net/dio-0.0.6 redis swift/swift
PHP Warning:  PHP Startup: Unable to load dynamic library '/usr/lib/php5/20121212+lfs/dio.so' - /usr/lib/php5/20121212+lfs/dio.so: cannot open shared object file: No such file or directory in Unknown on line 0
PHP Warning:  PHP Startup: Unable to load dynamic library '/usr/lib/php5/20121212+lfs/redis.so' - /usr/lib/php5/20121212+lfs/redis.so: cannot open shared object file: No such file or directory in Unknown on line 0
Channel "pear.swiftmailer.org" is already initialized
downloading dio-0.0.6.tgz ...
Starting to download dio-0.0.6.tgz (18,811 bytes)
......done: 18,811 bytes
could not extract the package.xml file from "/build/php5-8gpaOy/php5-5.5.9+dfsg/pear-build-download/dio-0.0.6.tgz"
Download of "pecl/dio" succeeded, but it is not a valid package archive
Error: cannot download "pecl/dio"
downloading redis-2.2.7.tgz ...
Starting to download redis-2.2.7.tgz (134,340 bytes)
...done: 134,340 bytes
could not extract the package.xml file from "/build/php5-8gpaOy/php5-5.5.9+dfsg/pear-build-download/redis-2.2.7.tgz"
Download of "pecl/redis" succeeded, but it is not a valid package archive
Error: cannot download "pecl/redis"
downloading Swift-5.1.0.tgz ...
Starting to download Swift-5.1.0.tgz (113,740 bytes)
...done: 113,740 bytes
could not extract the package.xml file from "/build/php5-8gpaOy/php5-5.5.9+dfsg/pear-build-download/Swift-5.1.0.tgz"
Download of "swift/swift" succeeded, but it is not a valid package archive
Error: cannot download "swift/Swift"
Download failed
install failed
Help me please!!!!
thank!!!
Re: fail pecl.php.net swift/swift
Is it a Raspberry Pi? Are you using this installation guide?
camilosti's picture
Hi Paul
I am using a PC with ubuntu 14.04 lts installation in clean.
The old installation on another PC I have installed it on Ubuntu 12.04 installation that time and gave no problems.
I am following the steps in this guide:
https://github.com/emoncms/emoncms/blob/9.0/docs/LinuxInstall.md
Any suggestions ?
Thank you
Sorry, I know very little about Raspbian, but even less about Ubunto. Hopefully someone else will.
Sounds similar to what this user describes:
The problem is that Ubuntu has replaced these libraries, but does not disable the config files
The solution - in that particular instance - is described here, the last post in the thread.
In essence, he deleted the associated .ini files.
