Input calculations
I think this is possible but have failed so far to get it to work.... wondering if someone might be able to point me in the right direction?
I have 3 Inputs:
InputA, InputB, InputC and would like to calculate inputD from them like so:
InputD = InputC/(InputA-InputB)
Fingers crossed it can be done :-)
Cheers.
robur's picture
Re: Input calculations
Hmmmm, I think I can see how this could work but need to be able to calculate a reciprocal of an INPUT value, wonder if this is possible?
A little context would go a long way and some indication of system set up emoncms version etc will help, but assuming you are referring to inputs to emoncms, I think most versions will probably do what (I think) you are after. although v9 may make the calculations easier.
To calculate "InputD" you could use the "-input" (or -feed if B is logged) process to subtract B from A and log that to a feed eg "InputAminusB", in the "InputC" proceslist you would then use "/ feed" with the "InputAminusB" feed to arrive at "InputD".
For the reciprocal you need to use the "reset to zero" process that gives you a clean slate at any time in the processlist. After that add a "+ 1 calibration" on which you can then use a "/ input".
robur's picture
Hi Paul,
Thanks for your reply and apologies for the flakey question - you're quite right :-)  This was indeed an EmnCMS question re: V8.  Now working with V9 which is looking very nice indeed and much easier to make the calculations.
Thanks again.
