Minor issue in new v9 feeds UI
Had to re-create some feeds the other day and noticed the following. The new feeds are created ok and seem to be working fine, but they are being grouped under a different *node* - i.e "Node 1" instead of "Node: 1" where my original (pre-v9) feeds are.
Obviously pretty minor but would be good to resolve. I don't want to have to re-create all my old feeds if possible - is this a simple fix?
chaveiro's picture
Re: Minor issue in new v9 feeds UI
That is not an issue with the input node id, the : character was removed from the ui.
Its easy to group different feeds together in v9
If you edit the feed (the pencil icon) and add the same tag to all of the feeds that you want in a group, they will all appear under that tag name.
For example, I added the tag name 'weather' to all feeds relating to weather - temp, windspeed, etc. Now instead of 'Node: 1', I have the group name 'weather'.
I think that your 'Node 1' and 'Node: 1' problem has arisen from tags that may have been created in a earlier version.
sumnerboy's picture
Apologies guys - you are dead right. I didn't realise this was just the tag name (since the tag column was empty in the list). I thought it was some internally generated grouping key that had changed in between versions. I edited each of my legacy feeds and updated the tag to "Node x" and everything looks good now.
Thanks for the prompt response!
