MQTT reloading config [CLOSED]
One question... my EMONCMS.LOG file has everytime the message "MQTT INFO Reloading config".​
What this means? Why should MQTT read configuration everytime? Any wrong configuration?
I have emonSD-17Jun2015 image.
Thanx!
2015-8-25 16:21:41 MQTT INFO Reloading config
2015-8-25 16:21:41 MQTT INFO Received mqtt message: emonhub/rx/5/values 96,87,11,3,125,29
2015-8-25 16:21:44 MQTT INFO Received mqtt message: emonhub/rx/5/values 95,90,11,2,125,29
2015-8-25 16:21:47 MQTT INFO Reloading config
2015-8-25 16:21:47 MQTT INFO Received mqtt message: emonhub/rx/5/values 97,88,9,3,124,29
2015-8-25 16:21:50 MQTT INFO Received mqtt message: emonhub/rx/5/values 97,89,10,2,125,29
2015-8-25 16:21:52 MQTT INFO Received mqtt message: emonhub/rx/5/values 97,89,9,2,124,29
2015-8-25 16:21:53 MQTT INFO Reloading config
2015-8-25 16:21:55 MQTT INFO Received mqtt message: emonhub/rx/5/values 98,89,9,3,125,29
2015-8-25 16:21:58 MQTT INFO Received mqtt message: emonhub/rx/5/values 98,89,10,3,126,29
2015-8-25 16:21:59 MQTT INFO Reloading config
SnaxMuppet's picture
Re: MQTT reloading config [CLOSED]
I am getting this too...
allmac's picture
Is this usual ?? Is there no problem??
This is currently how the config update works, via cron every 5secs. I'm hoping that will change in the not too distant future.
