U.S. EmonPi
I have a PI that I have attached the RF Board to and I have installed the latest SD Card Image of the EmonPI on it.  I have an EmonTX and I am going to have that transmit to the EmonPI.  I live in the U.S. and I am unsure of what additional steps I need to take in settings this up.
Re: U.S. EmonPi
You sound a bit mixed up there. EmonPi is a Raspberry Pi with a stripped-down (2 current inputs only) emonTx inside it. I think you have your Raspberry Pi as an emonBase (your setup is this?) on which you want to run the emonCMS software. Is that correct?
There's a Building Blocks page about using your emonTx in the USA, have you seen that?
JBlackham's picture
Re: U.S. EmonPi
EmonBase with EmonTX
