Removing nodes from node list?
Hi guys,
How can I remove nodes from the nodes list? I have deleted the blocks from the emonhub.conf however in the nodes tab of the web interface on the RPi the old nodes still show?
Re: Removing nodes from node list?
On the page of the node you wish to delete there should be a "delete node" button, that should delete the node, if you haven't removed it from the emonhub.conf first it will pop straight back up though.
tomstephens89's picture
Nice one, did see the button, didn't put two and two together about removing from the nodes list first. Doh!
