emonGLCD time update
I'm experiencing a time update problem whereby the time on my emonGLCD only displays uptime instead of normal time. I am running emoncms installed on a Raspberry Pi and the GLCD is picking up the power readings from emonTX v2.
I've added "sendtimeinterval = 60" to emonhub.conf and restarted the emonhub service (also with debug):
2015-07-27 16:52:29,465 INFO EmonHub Pre-Release Development Version (rc1.2)
2015-07-27 16:52:29,468 INFO Opening hub...
2015-07-27 16:52:29,471 INFO Logging level set to DEBUG
2015-07-27 16:52:29,484 INFO Creating EmonHubEmoncmsReporter 'emonCMS'
2015-07-27 16:52:29,489 INFO Set up reporter 'emonCMS' (buffer: memory | size: 1000)
2015-07-27 16:52:29,504 INFO Setting emonCMS url: http://localhost/emoncms
2015-07-27 16:52:29,506 INFO Setting emonCMS apikey: set
2015-07-27 16:52:29,509 INFO Creating EmonHubJeeInterfacer 'RFM2Pi'
2015-07-27 16:52:29,524 DEBUG Opening serial port: /dev/ttyAMA0 @ 38400 bits/s
2015-07-27 16:52:31,533 DEBUG Opening serial port: /dev/ttyAMA0 @ 9600 bits/s
2015-07-27 16:52:35,543 INFO RFM2Pi device firmware version & configuration: not available
2015-07-27 16:52:35,546 INFO Setting RFM2Pi frequency: 433 (4b)
2015-07-27 16:52:36,550 INFO Setting RFM2Pi group: 210 (210g)
2015-07-27 16:52:37,564 INFO Setting RFM2Pi quiet: 1 (1q)
2015-07-27 16:52:38,568 INFO Setting RFM2Pi baseid: 15 (15i)
2015-07-27 16:52:39,587 DEBUG RFM2Pi acknowledged command: > 4b
2015-07-27 16:52:40,024 DEBUG RFM2Pi acknowledged command: > 210g
2015-07-27 16:52:40,458 DEBUG 1 NEW FRAME : 1438012360.46  20 202 10
2015-07-27 16:52:40,461 DEBUG 1 Timestamp : 1438012360.46
2015-07-27 16:52:40,464 DEBUG 1      Node : 20
2015-07-27 16:52:40,466 DEBUG 1    Values : [2762]
2015-07-27 16:52:40,486 DEBUG 1 Append to 'emonCMS' buffer => time: 1438012360.46, data: [20, 2762], ref: 1
2015-07-27 16:52:40,590 INFO emonCMS sending: http://localhost/emoncms/input/bulk.json?apikey=E-M-O-N-C-M-S-A-P-I-K-E-Y&data=[[1438012360.46,20,2762]]&sentat=1438012360
2015-07-27 16:52:40,691 DEBUG RFM2Pi acknowledged command: > 1q
2015-07-27 16:52:40,778 DEBUG emonCMS acknowledged receipt with 'ok' from http://localhost/emoncms
2015-07-27 16:52:40,919 DEBUG RFM2Pi acknowledged command: > 15i
Previous posts have suggested that there should be a "DEBUG Broadcasting time: " line but I haven't seen one.
Any ideas anyone? Many thanks.
Re: emonGLCD time update
You need " interval" in emonhub.conf not "sendtimeinterval", the norm is to use "interval = 300" (300s being 5mins).
BTW you don't need to restart emonhub when updating the settings, the changes are picked up and implemented in runtime.
gapintheclouds's picture
Hi Paul.
Thanks for that. Excellent! And thanks for the not-having-to-restart-emonhub tip :-).
Cheers.
