Display RAW feed data from PHP engines for debuging
To help debug files on disk, here are some simple linux comands that help.
PHPFINA:
Check metadada file feed 149 :
od -i 149.meta
0000000           0           0           5  1437930520
  • 5 is interval
  • 1437930520 is start time in unix epoch
Check dat file:
od -f -j 0 -N 16 149.dat
0000000               0   0.00045226078   0.00074822176    0.0011848678
  • 0 is start time, calculated with unix timestamps as: ((desired time - start time from meta) * 4)
  • 16 is number of data points to show after start time: (num * 4)
  • The response gives the value of the data points for the selected start time.
Re: Display RAW feed data from PHP engines for debuging
This is really useful.
