How to post data to EmonPi/EmonHub using REST API ?
This may look like a silly question but... I can't get data posted using REST API to appear in Nodes and Feed of my EmonPi :-(
I used to post data using a REST call looking like this :
http://myemoncms/emoncms/input/post.json?node=40&apikey=myapikey&json={"humidity": 50.3}
Is there still a REST call based on a "GET" which allows posting data with named values ?
Thanks.
JS
jsroques's picture
Re: How to post data to EmonPi/EmonHub using REST API ?
Hello again,
So, as I understood it, there is no more "input" module in EmonPi to keep writes to a low level. So I can't use the GET call anymore. I am tryng to use the node POST call but I can't figure out how the pass on my emoncms key. I could not find any documentation on this.
Could someone tell me how I should pass the key ?
Thanks.
JS
jsroques's picture
Ok... I did find out.
It is just as simple as for the GET : pass the key in the URL.
JS
