Events module test works but not automatically
Running emoncms 8.4.0. I recently installed the events module. I have a feed that is either 0 or 1. In the case this feed is 0 I want to set another feed to 0 (i.e. reset a kwd feed to 0).
So I have an event like so:
if feed1 == 0 set feed2 to 0
It works perfectly if I use the test button on the events page but it doesn't work by itself.
Any ideas?
hendersoniain's picture
Re: Events module test works but not automatically
Anything anyone? I can't find anyone with the same problem elsewhere in the forum. Thanks.
simsasaile's picture
Same here, have no clue what is wrong. But Last True shows always: Last true: 1970-1-1 01:00:00
So probably here is something wrong. I'm using emoncms 8.5.2
Have you both used the "update & check" in admin ?
Yes have tried "update & check" several times - always telling me the database is up to date and nothing to do.
As I say it all works fine from the test button. I have tried setting the timing to various settings from mute, 5seconds, 1hour etc. - always no difference.
Also on Events page the True or False flag is set correctly depending on the monitored feed. It just doesn't work automatically.
