How do I delete rf_fail
I have an account that has tons of rf_fail inputs. How can I delete them? I'm hosting myself using version 8.4.
They are all 1.00 for the value. I think they had to do with a sensor I had that isn't working right. I have removed it. But the huge list of rf_fails seems to be freezing my page.
[The next paragraph was created in a new thread, but is so closely related that I have moved it to here. - Moderator (RW)]
Alternatively, how do I delete the account and all the data with it? I have one that is corrupted (has so many rf_fails that the page script freezes) and I have had to restart the account. But I haven't found a decent way to delete the old account. I'm hosting myself on version 8.4
Re: How do I delete rf_fail
The rf_fails can be caused by NanodeRF's posting to emoncms v8.4 without a node id, see Potential Problem with NanodeRF base station sketch and a solution for more info.
Clearing the inputs can be done with a script see Cannot delete inputs. Where are they stored?
As for the other account and it's associated feeds, inputs dashboards etc etc it will probably be easiest to use phpmyadmin which can be easily installed using sudo apt-get install phpmyadmin
​Paul
