Feeds view is updating but no data is being written.
Hi all,
i'm emoncms newbie.
My configuration is emonBase - Raspberry Pi B+ and RFM69Pi RF adapter.
I installed last .img version (emonSD-17Jun2015.img) on 8GB SD Card.
Everything works fine, but when i try to create feeds and view same data in Vis, nothing happens.
The local log won't start.
I tried on emocms.org and remote logging and all works fine.
The service feedwriter status is NOT RUNNING! I try to restart the service but won't.
Can someone please help me?
Gianluca
Re: Feeds view is updating but no data is being written.
what message do you get when starting the feedwriter service?
giangitesta's picture
no error message only "Log is turned off - Starting RPI". After when I request status (sudo service feedwriter status) is always stopped.
However, I went around the problem. I set the remote cms within the file emonhub.conf let it point to the local copy:
[[emoncmsorg]]
    [[[init_settings]]]
    [[[runtimesettings]]]
        pubchannels = ToRFM12,
        subchannels = ToEmonCMS,
        url = http://emoncms.org
        #url = http://192.168.1.100
        apikey = xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
        #apikey = my local write API key
        senddata = 1
        sendstatus = 1
I rebooted and everything started to work.
After this I reset configuration to default values (comment on local settings) and now it works.
sudo service feedwriter status now report:
Log is turned off
running
I don't now why!
Gianluca
