is voltage constant like calibration
Hi all,
is calibration == voltage constant ?
can you explain What are the values taken from
voltage constant = 230 × 11 ÷ (9 × 1.20) = 234.26
I guess:
230  = AC input transformer
11    =  partition ratio?
9      =   out voltage  adapter
1.20 = ??
Thank you very much
calypso_rae's picture
Re: is voltage constant like calibration
My guess is that the RMS output from the unloaded transformer will be approx 20% higher that its nominal value of 9V.  This signal is then divided by a 10:1 pair of resistors so only 1 eleventh reaches the ADC.  So the RMS signal at the ADC's input will be (9V * 1.2) / 11 = 0.9818 Vrms.
The actual voltage on the mains is nominally 230 Vrms, so the cal factor needs to be 230 / 0.9818 = 234.26.
That page was written before the change to Ideal as the supplier of ac adapters. If you look at the Ideal data sheet, the actual output voltage under no-load conditions is specified, so there is no need to guess a value for transformer regulation.
But there are in fact three constants that affect calibration. All the details are in Building Blocks.
