Errors i have spotted in Extended version
just a few odd's i have noted
Temp cylinder widget does not show up in public dashboard, but it does as soon i edit the dashboard... feed is public.... the cylinder does not show up at all
Same goes for dials, they do not show up either but does in edit mode
any clue if i have done something wrong?
Fix was to go in admin and do a check and apply them
chaveiro's picture
Re: Errors i have spotted in Extended version
Are you using latest 8.5.1 version?
boelle's picture
same answer as here : http://openenergymonitor.org/emon/node/10752
yes, did the git pull to update same day as i answered if i used the latest
boelle's picture
just fired up the pi to get some import from OpenTRV units going
yes i'm on 8,5.1 XT...
not sure what is wrong here or shy it should be hard to do a muligraph.... again why do i have to go through VIS
why not just have a multigraph on dashboard where there is always one more dropdown than the one you select...
rbreuss's picture
Im testing 8.5.1 XT (last update) and there is not possible to create multigraph in VIS. Not exactly so - you can create New Multigraph, but there is not available tool for selecting feeds in this multigraph, like it was available in former versions..
​Radek
chaveiro's picture
rbreuss, the multigraph was broken on xt a commit ago, fix is waiting merge.
You can get latest from my branch while it's not merged on official : https://github.com/chaveiro/emoncms/tree/Extended
boelle's picture
will the dials get fixed too?
