Multigraph problem on the Extended version
Tried to create a multigraph on the extended version
The dropdownbox contains no items....
is it me that does something wrong?
i just did a git pull so should be up to date
boelle's picture
Re: Multigraph problem on the Extended version
bummer... search function worked:
http://openenergymonitor.org/emon/node/5332
boelle's picture
one thing i then cant find is how to delete a entry in Vis...
boelle's picture
also i cant select any feeds and it only says to check that the type on the feed is set... mine is set to real time
chaveiro's picture
Running latest version ?
boelle's picture
yes
