Multigraph timeout on Raspberry Pi
i have some sensors which i monitor with a raspberry pi 2. Newest release Emoncms.
On my LAN everything is fine with the Emoncms Web page, but if i go over WAN - Dyns - Fritzbox - Raspi and want to open the same page i get a timeout (Zeitüberschreitung)
If i do the same without Dyns, so with the actual IP its the same, timeout.
The problem is with all graph, if i have only one feed or more, doesn matter
Maybe i do sth wrong, please advise what i can try.
ths
Thomas
tomrossi's picture
Re: Multigraph timeout on Raspberry Pi
is there no one who can help me?
Hello Thomas, is it a multigraph on a dashboard that is timing out? It may be because the path for widgets in dashboards are set to the local LAN ip address, try editing the multigraph from the WAN address and saving the multigraph again this will change the path and it should work.
tomrossi's picture
this did the trick. Maybe i can ask you some more, for you simple questions.
Is there a way to add extra users, only with read access, i cannot see any button?
Is there a sms module? I use the email events, it would be nice to have the same witn sms?
regards
