Emoncms on shared linux hosting - requires redis-server
Not sure where to post this but it might help those who want to host emoncms on a shared linux host service.
It seems that emnocms requires redis-server to be installed and the host I use does not and will not install this package.
Without redis-server, emoncms does not let you know that it is not fully working. The only symptoms (for me) was that the "kwh-kwh/d" and "rate of change" input processes do not work (show as "inactive" in the feeds list).
It would probably be worth mentioning this in the "shared linux hosting" page: https://github.com/emoncms/emoncms/blob/master/docs/SharedLinuxHostingInstall.md
Thanks for an excellent software suite
Mike
Re: Emoncms on shared linux hosting - requires redis-server
Mike,
Did you change the $redis_enabled line in settings.php from true to false?
I made that change, stopped redis, changed /etc/init.d to keep redis from starting, rebooted my VPS and everything is still working. (after rebooting, I verified via ps -ef that redis was not running) I have emoncms installed on a linux box at OVH.com. (They call it a VPS -- virtual private server)
Esk Energy's picture
Hi Bill
Yes, and the "kwh-kwh/d" and "rate of change" input processes are still not working (showing as "inactive").
I tried deleting and recreating the processes/feeds after disabling "$redis_enabled" to check as well - same result.
Mike
Bill
When you said you disabled redis and everything worked OK, can you confirm if that included a feed derived from either a kwh-kwh/d process or a rate of change process?
Mike
I went back to my VPS and re-enabled/re-started redis, then created two dummy inputs/feeds. One was kWh to kWh/d, the other, rate of change. I'm seeing the same thing you are, i.e. both are inactive.
Hi Bill
So it looks like emoncms needs redis-server - unfortunately for me...
Thanks for investigating - I hope this helps someone as it's not in the documentation.
Mike
