emonTxV3_4_3Phase_Voltage does not communicate over rfm69cw
Hello all,
I have a 2 or 3 week old emonTx v3.4, which was working fine with the default discrete sampling sketch.
I have uploaded the latest 3 phase sketch in git (4th May), it apparently runs well and sends out the data over the serial line, however, I can no longer receive anything via jeelink+emonhub (not a single byte).
I have checked all the configurations for RFM, and cannot find anything wrong.
I am using RFM69CW, 433Mhz, Group 210.
Any ideas what could be wrong, or what to look for?
Re: emonTxV3_4_3Phase_Voltage does not communicate over rfm69cw
Experiment with changing the frequency. According to the RFM69CW data sheet, the frequency setting (Frf) should be 0xC64000, whereas if I remember correctly, I worked out that JeeLib set it to 0xC68000
So try changing line 619 to:
    writeReg(0x08, 0x80); // RegFrfMid
I have only 868 MHz modules. I tested over a range of only about 100 mm, so it worked on 433 MHz at that range. It doesn't work over about 3 m with 0xC64000, whereas it does most of the time with 0xC68000.
jdpmendes's picture
Thanks, this was exactly the reason!
It appears to want to work at 433.75 MHz, not 433 MHz. I'll get Glyn to change it on GitHub.
I've checked line 619 to: writeReg(0x08, 0x80); // RegFrfLsb
​Please confirm this is correct?
https://github.com/openenergymonitor/emonTxFirmware/blob/master/emonTxV3/RFM/emonTxV3.4/emonTxV3_4_3Phase_Voltage/emonTxV3_4_3Phase_Voltage.ino#L619
Robert: have you got a GitHub account? Can I give you push access so you can dive straight in to update the code. This can easily be done just by clicking edit just like a drupal page: https://help.github.com/articles/editing-files-in-your-repository/
No (to the GitHub account, and I haven't figured out how to use (i.e. make it useful to me, as distinct from operate) GitHub yet!) - and I need to check the other frequencies too. I shouldn't have believed the comments. I hope to get back to this in a day or two.
