Upgrade to 8.5 extended: feeds not updating
I am running the (latest?) version of Emoncms. I decided to upgrade to the extended version. I can see all data coming in correctly when looking at the input, but somehow the feeds are not updating. Am I doing something wrong? I, of course, updated the settings.php to allow all the feed types to be available.
fversteegen's picture
Re: Upgrade to 8.5 extended: feeds not updating
Nobody? I am sure it is something small (and probably stupid) that I am overlooking...
What checks have you done yourself?
Are there any errors reported in the emonhub log?
jonrescca's picture
The issue I had, was that the timezone was not properly set. You can find that post here: http://openenergymonitor.org/emon/node/10538
Thanks for the suggestion @jonrescca! Your solution works to get the feeds updating again. There is however 1 additional problem: it looks like the old values of the feeds are not available anymore. See screenshot below (from the new extended branch) and compare it with the same screenshot from my old installation below that.
@Paul Reed: I cannot create any logs since log4php cannot be installed on my, shared, hosting account.
EDIT: it appears to be an issue with the upgrade to 8.5 as I have tried to install the normal 8.5 version and it delivers the same result...
Extended branch:
Old installation:
 Deleteed duplicate post - BT
chaveiro's picture
