8.5: Error in PHP
Hello!
I have 8.5 running on my provider webspace. I added 2 feed on some nodes:
kwhd & max.
It seems, since this, I have this error in the php log:
[Wed Apr 22 14:52:51 2015] [error] [client 77.] PHP Fatal error:  Call to a member function setTimezone() on a non-object in /is/htdocs/wp11156121_WBEON0I00D/www/emoncms/Modules/input/process_model.php on line 668
[Wed Apr 22 14:52:53 2015] [error] [client 77.] PHP Fatal error:  Call to a member function setTimezone() on a non-object in /is/htdocs/wp11156121_WBEON0I00D/www/emoncms/Modules/input/process_model.php on line 668
The feed is not updated ... I see the actual value on "Inputs", but feed is inactive.
Any idea?
unique24's picture
Re: 8.5: Error in PHP
Edit .... seems it comes since he wrote "PHPTIMESERIES" feeds
unique24's picture
Has no one an idea why he did not display the kwhd & max?
Have you selected the correct time zone in 'My Account'?
unique24's picture
It was not absolut correct ... thank you.
I fix it, but still no records.
What is showing in the php log now, are there still errors?
Maybe the same issue as http://openenergymonitor.org/emon/node/10508
