Install on provider
Hello!
I try to install emoncms on my webspace from my provider "Host Europe".
I copy all files with FTP, setup MySql and the setting.php.
But when I try to open the site, I get an error:
The script could not be executed correctly.
Please refer to your error log for details about this error. You find it in your KIS under the item "Administration > *YOUR PRODUCT* > *YOUR PACKAGE* > Logfiles". Further information can also be found in our FAQ.
In the php 5.3 log I found:
[Sun Apr 19 17:48:20 2015] [alert] [client ***.***.***.***] /is/htdocs/wp11156121_WBEON0I00D/www/emoncms/.htaccess: Options not allowed here
What is wrong with the .htaccess?
I disabled "Options -Indexes", but still same problem.
Thank you
Re: Install on provider
I think you need to ask the Host Europe support desk. I suspect they do not allow you to have a .htaccess file. If that is the case, you need to change your provider.
unique24's picture
Hello!
I found the problem!
I have to disable "Option -Indexes", but there was a second line in the .htaccess.
Now he logging.
